CNC Prop : 1.8 Pitch : 32 to 54mm
Product ID cnc-xx18350
In Stock 1
Price: $24.95
3-blade, Magnalium 7075 propeller, 1.8 Pitch in Reverse Rotation.  Magnalium 7075 propeller.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-321835032 mm (1.26")57.402.26"1/8"
cnc-341835034 mm (1.34")61.212.41"1/8"
cnc-481835048 mm (1.89")86.363.40"3/16"
cnc-501835050 mm (1.97")90.173.55"3/16"
cnc-521835052 mm (2.05")93.733.69"3/16"
cnc-541835054 mm (2.13")97.283.83"3/16"
 Specifications:
  • Pitch ratio: 1.8
  • Blades: 3
  • Material:  Magnalium 7075 alloy
  • Mounting: 3/16" Drive dog, depending on the prop size.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
CNC Prop : 1.8 Pitch : Reverse Rotation : 48 to 54mm
Product ID cnc-xx18350-R
Price$24.95
