CNC High Pitched Aluminum Prop : Reversed Rotation : 38 to 48mm
Product ID cnc-xx19250-R
Price: $19.95
CNC  Reversed rotation, Magnalium 7075 metal propeller. 1.9" Pitch Ratio. If you have used a similarly sized 1.4-pitch-ratio prop, this will be the next prop to test.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 CNC 1.9 Pitch Right-Hand Propeller Size Chart
Part NumberDiameter (mm / in)Pitch RatioPitch (mm)Pitch (in)Drive Shaft
cnc-4019250-R40 mm (1.57")1.975.702.983/16"
cnc-4219250-R42 mm (1.65")1.979.503.133/16"
cnc-4519250-R45 mm (1.77")1.985.343.363/16"
cnc-4819250-R48 mm (1.89")1.991.183.593/16"
Specifications:
  • Pitch ratio: 1.9
  • Blades: 2
  • Material: CNC Magnalium 7075 metal
  • Mounting: 3/16" (4.75mm) Drive dog
  • Rotation: Clockwise. ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
« Previous | Next »
CNC High Pitched Aluminum Prop :  3/16 bore : 38 to 48mm
1 of 4
Price$19.95
