Delta Force DF45 MK-ll: Kevlar Bare Hull (38.5" 980mm)
Product ID df-DF45-MK-ll-kevlar
In Stock 0
Price: $399.99
Delta Force DF45 MK-ll Epoxy and Kevlar Boat Hull.
This super strong and lightweight epoxy and Kevlar hull is built for Fast Electric Rc Boat Racing. Designed as a deep vee with a small rear pad makes this boat handles well and achieves an excellent top speed. The hull and deck are joined leaving only a minimal pencil-width seam, similar to the European-designed hulls. This unique look can be painted or left alone and run as is with the exposed Kevlar bottom.
Specs:
Size: 980mm (38.5") x 290mm (11.4") x 95mm (3.9")
Weight: 1600g (3.52lb) approx
Material: Epoxy with the bottom in Carbon Kevlar.
Comes as a bare hull.
Basic Power & Hardware Recommendations:
6s to 8s Lipo Leopard 4092, Neu 1527, Tp-4060 or larger-sized motors.
Hardware: Speedmaster Stinger 3/16" Size,
Speedmaster dual pickup rudder 4" setback
1 Product Reviews - Average rating 5 / 5 (Show All)
Smoove operator
Steve S - 16th October 2024
FE boat enthusiast, have several hull styles and just love how easy this was to set up. Running a SSS 4092/2140kv w/ castle xlx2, speedmaster hardware. Tested with abc 1715/3 and a single 6s/7200mah. Easy mid 60s for laps on maiden, plenty throttle left aread more
