Etti 4mm to 3/16"(4.75mm) prop adapter
Product ID etti-a126
In Stock 22
Price: $5.99
Etti 4mm to 3/16"(4.75mm) prop adapter.
This is used if you are trying to adapt a 3/16"(4.75mm) propeller to a 4mm threaded shaft.
How this works...
The threaded drive dog is first threaded onto your 4mm threaded shaft. Slide your propeller onto your shaft. Then install and tighten the included adapter/propeller nut. Keep in mind, you need enough threads on your shaft to fit the prop hub you are trying to adapt.
Includes:
(1)Drive Dog
(1) 3/16"(4.75mm) adapter/propeller nut
Fits:
M4 threaded shafts
OSE Propeller Adapter
1 of 5
Product ID ose-83400
Price$1.99
2mm wire drive with 4mm threaded end
1 of 2
Product ID tfl-510B03
Price$7.95
ROV Adapter 1/8 Motor to 4mm or 3/16" propeller
1 of 2
Product ID ose-83397
Price$11.95
