ETTI Race 150 Brushless ESC 7.2volts to 30 volts ( 2-7 lipo / 6-20 NiMH). 150 amp constant Electronic Speed Control(ESC). This is a water resistant esc with water cooling for Fast Electric rc boaters. Specs: Weight: 100g, 120g with wires. Wire gauge: 10 gauge battery side : 12 gauge motor side. Dimension: 95x50x13mm Amp rating: 150A Continuous : 300A Quick burst Battery type: 2-7 Li-Po or 6-20 Ni-MH/Ni-Cd (Low volt cut off per cell ) BEC: No IR: 0.001 Aluminum Water Cooling Plate Temperature Overloads Protection: 90 °C Suggested Timing: 1° (2-4 poles motor) : 7° (6-8 poles motor) : 15° (10-14 poles motor) : 30° (10-14 poles motor)
