Etti Capacitor Bank for High Voltage 63V 5000u.
Note: Pictures 2 and 3 will show how this can be installed onto an esc.
Power Cap's Module is specially designed for SAW racing and increases the power of ESC. Equipped with 5 x RUBYCON 63V, 1000u RX 30 Series 130 ¢J Capacitors
Recommended for up to 14s Maximum.
WARNING: If any capacitors seem to bulge, start to deform, leak, or pop, stop using them IMMEDIATELY!!! If Capacitors fail they can explode and cause injury.
It is generally reported that capacitor failures can be attributed to:
1) Heating, causing a capacitor to swell and explode.
2) Drying of the liquid electrolytic inside from various causes, such as defects, leaking, and even cleaning.
3) Capacitors re-form over time to meet a usual and expected voltage. Surges that are not normal can cause sudden failure.
4) The older they get the greater the incidence of failure.
5)High-current motor setups will tend to kill the caps quickly (because of the large voltage changes).
Includes: (1) Cap bank, esc is shown for display purposes only.
