3S Super Power Cap's Module
Product ID etti-e080
In Stock 4
Price: $29.99
3S Super Power Cap's Module is specially designed for increasing the power of ESC.
Designed for 3s Lipo Maximum.
Specification:
Dimension : 55 x 38 x 20mm (LxWxH)
Max working voltage : 13V
Operating Temp. Range: -40C to 60C
Capacity: 2F
WARNING: If any capacitors seem to bulge, start to deform, leak or pop, stop using them IMMEDIATELY!!! If Capacitors fail they can explode and cause injury.
It is generally reported that capacitor failures can be attributed to:
1) Heating, causing a capacitor to swell and explode.
2) Drying of the liquid electrolytic inside from various causes, such as defects, leaking and even cleaning.
3) Capacitors re-form over time to meet a usual and expected voltage. Surges that are not normal can cause sudden failure.
4) The older they get the greater the incidence of failure.
5)High-current motor setup will tend to kill the caps quickly (because of the large voltage changes).
