3548 Brushless Outrunner Motor 35mm x 48mm
Product ID flh-d3548
List Price: $34.95
Price: $24.95
3548 Brushless Outrunner Motor 35mm x 48mm.
Custom-made to work with the bel-7800, bel-2041-alu, and ose-90100 drive systems.
RPM Options:
1500kv for 3s to 5s Lipo.
2000kv for 3s to 4s Lipo.
Specs:
No load current: 3.1A
Max power: 910W
Internal resistance: 0.023 ohm
Weight: 160g (includ
ing connectors)
Shaft diameter: 5mm
Mounting Holes: Comes with both 19mm and 25mm spacing. Works with most 540 or 36mm motor mounts.
Dimensions: 35x48m
Max thrust: 2150g
Comes with 4mm male bullet plug preinstalled.
Requires:
(3) 4mm Female bullet connectors
(2) Mounting screws: 3mm thread. The length required will be based on the thickness of the motor mount being used.
« Previous | Next »
Scale Outboard with Metal Lower Unit: All Black
1 of 3
Product ID bel-2041-alu
Price$199.99
