48 inch open mono race build info
  • JD/QD
    • Dec 2013
    • 15
    Hey guys, I am a gas racer looking to build a 48 inch ARD Assault mono for the open mono class in my district. I scrolled through a bunch of threads here on the site and one common theme seems to be the castle 2028 motor. Seen a lot of different ESC’s used, Castle, MGM etc. This would not be my first FE boat but definitely the first one this large. I wanna make sure it’s durable and plenty fast. I already know the hull is the best rough water mono around for heat racing (IMO). Thanks for any and all help and suggestions. John
  • meangenesracing
    • Jun 2012
    • 1158
    What's your budget? Low end would be the 2028 and etti 220 esc
    • Doug Smock
      Moderator
      • 5272
      https://forums.offshoreelectrics.com...or-John-Snider
      NEU 2230 1Y 725kv, Castle Hydra HV200, M cut Octura X465, 10s2P.
      This set up (as is) held the IMPBA T Mono 1/3 mile oval record and still holds the 1/4 mile oval record.
      And Ken, it will hold the 1/3 record again...
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • JD/QD
        • Dec 2013
        • 15
        Hey Gene, thanks for the reply. Low end is fine with me as long as it can get the job done repeatedly. How hard would I be pushing that motor? How long can the bigger motors go between rebuilds if they need to be rebuilt at all?
        • JD/QD
          • Dec 2013
          • 15
          This set up (as is) held the IMPBA T Mono 1/3 mile oval record and still holds the 1/4 mile oval recorquited.
          Doug, thanks for your response. That boat is impressive, the price on the motor is as well, lol. Any idea what the top speed was in that video?
          I’ve seen quite a few gas Speedcrafts run well also. Does Castle still make those ESC’s? I thought I heard they were not.
          • Doug Smock
            Moderator
            • 5272
            I never put a GPS in the boat but it will run with the best out there. The motor doesn't know it's in the boat. I'd love to put it in a 54-55" boat with more control.
            I had no idea the motor was 8 bills now. Yes Castle is gone. Etti, ZTW, or Swordfish would be your go to control now.
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • meangenesracing
              • Jun 2012
              • 1158
              I personally have never had an issue with the Castle 2028 and see many people on here use them. For the price imo can't be beat. Maybe someone else can chime in here. And I prefer the etti esc's a little hard sometimes to program you need a quiet place and need to concentrate on the beeps and tones.
              • meangenesracing
                • Jun 2012
                • 1158
                Hey Doug, what's an M cut on a prop? Thanks bud.
                • Doug Smock
                  Moderator
                  • 5272
                  Hey Geno,
                  I cut the tongue off like the M series Octuras. https://www.offshoreelectrics.com/pr...ctura+M+Series
                  They are progressive pitch props so the tongue can keep you from getting the most out of the prop. You can see in the video that the boat doesn't need the additional blade area to get up. I wish they offered the whole X series in a M series. It sure would save a lot of work.
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • JD/QD
                    • Dec 2013
                    • 15
                    Thanks for the info Gene and Doug. I talked to Ken Haines at our race In Broward this weekend and picked his brain a bit. He likes the Neu 2230 motor as well.
                    • rayzerdesigns
                      • Dec 2013
                      • 1228
                      Can’t go wrong with a castle 2028 and swordfish 300x
                      • JD/QD
                        • Dec 2013
                        • 15
                        Thanks for the suggestion Ray. This type of set up would need to be run on 10S correct?
                        • rayzerdesigns
                          • Dec 2013
                          • 1228
                          Yes.. or 8s.. I’ve run it both ways.. 8s I run a 72mm prop.. 10s a 63mm prop
                          • Doug Smock
                            Moderator
                            • 5272
                            The price on the 2028 seems legit.
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • JD/QD
                              • Dec 2013
                              • 15
                              Again, good info, thanks. 2 or 3 blade? I believe someone said a 270/2 for their 2230/ hydra setup?
