Graupner Carbon K Series M4 Props : Reversed Rotation : 4mm threaded shafts : 31 to 42mm Props
Product ID grp-2318-L-series
Price: $4.99
These carbon fiber-reinforced props are light, sharp, and don't need balancing or sharpening!  NOTE: These are reverse rotation. Looking at the transom, these props spin clockwise. These are screw-on style to fit 4mm threaded shafts.
 Graupner 2318 L Series Carbon Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
grp-2318.31L31 mm (1.22")431.694 mm M4
grp-2318.36L36 mm (1.42")501.974 mm M4
grp-2318.39L39 mm (1.54")542.134 mm M4
grp-2318.42L42 mm (1.65")582.284 mm M4
Specifications:
  • Pitch ratio: 1.4
  • Blades: 2
  • Material: Carbon-fiber-reinforced plastic
  • Mounting: Drive dog
  • Rotation: Counterclockwise. ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
Graupner Carbon K Series M4 Props : 4mm threaded shafts : 26 to 45mm Props
1 of 3
Product ID grp-2318-series
Price$4.99
