Castle Creations BEC 10A Peak 25V Max Input SBEC
Product ID hh-cas-010-0004-00
In Stock 5
Price: $23.95
Castle Creations BEC Eliminator Circuit, Eliminates the need for a RX Pack!
Are you running a receiver pack or having it die in the middle of the lake? If Yes read on.
Tired of having a dead receiver pack ruin your day?
Tired of buying AA batteries to power your receiver? Need to shed some weight from your Fast Electric? If you answered yes to any of those 3 questions you have found the right product.
So you want to be free of the pains of running a Receiver (RX) battery pack? This BEC (battery eliminator circuit) product is for you. It uses your motor battery pack to supply your receiver with a selectable 4.8-9.0 volts at upto 10 amps.
At only 11 grams and 1.2" long this will fit almost anywhere!
Castle Link is Required to change change the from
the standard 5.1volt default setting.
Input voltage: 5v to 25.2v (2S to 6S LiPo)
 This is a Battery Eliminator Circuit Only and Not a Motor Speed Control.
