Castle Creations Capacitor Pack 8S (5v-35v) The Castle Creations (CC) CapPack is useful in all brushless motor applications, where it serves to give just that little boost needed to overcome ripples in the battery voltage caused by hard acceleration or long battery wires. Ripple voltage is hard on an ESC - adding the CC CapPack can help reduce the load on the controller's on-board capacitors. This CapPack uses four 560µF, 35V capacitors totaling 2240µF, which increases its ripple-reducing capabilities.It can be used with LiPo batteries up to 8 cells.
Specs:
Voltage: 2 to 8s (5v to 35v)Cap Specs: 4 x 560µF (2240µF total)
WARNING: If any capacitors seem to bulge, start to deform, leak or pop, stop using them IMMEDIATELY!!! If Capacitors fail they can explode and cause injury. It is generally reported that capacitor failures can be attributed to: 1) Heating, causing a capacitor to swell and explode.2) Drying of the liquid electrolyte from various causes, such as defects, leaking, and even cleaning. 3) Capacitors re-form over time to meet a usual and expected voltage. Non-normal surges can cause sudden failure. 4) The older they get, the greater the incidence of failure due to workloads.5)High-current motor setup will tend to kill the caps quickly (because of the large voltage changes). NOTE: The third picture shows a typical installation. ESC NOT included!!
