ProBoat Sonicwake Version 24" Self-Righting Brushless Deep-V RTR
Discounts Apply !
Free Shipping on Select Items
Product ID hh-prb-1992
List Price: $367.99
Price: $319.99
Proboat Sonicwake Version 24" Self-Righting Brushless Deep-V RTR
Free shipping while supplies last.
Features
  • Worry-free self-righting design
  • 35+ mph Spektrum brushless power system
  • Hassle-free SSL (Strap, Slide, Lock) battery installation
  • Easy-to-use Spektrum 3S LiPo and S120 USB-C charger
  • Ready to run – nothing else required
Sonicwake 24" Self-Righting Brushless Deep-V RTR, Blue Features
  • Durable injection-molded ABS hull and canopy
  • Damage-resistant breakaway rudder
  • Spektrum SLT2 2-channel 2.4GHz radio transmitter
  • Spektrum SR215 DSMR 2-channel sport receiver
  • Factory-installed 35+ mph Spektrum brushless power system
  • Spektrum 3542 2500Kv brushless marine outrunner motor
  • Spektrum 50A brushless marine ESC
  • Pro Boat 5.3kg 4.8-6V waterproof standard servo
  • Sturdy composite boat stand
MOLDED ABS HULL
The molded, factory-finished ABS deep-V hull knifes cleanly through the water for a smooth ride even in rough conditions. The canopy attaches securely using a single 1/4 turn locking tab. A double foam seal around the canopy prevents water from entering the hull.
SELF-RIGHTING DESIGN
Punch the throttle and power across lakes and ponds with no worries. If your Sonicwake 24" Deep-V flips over away from shore, it will quickly recover on its own and continue full speed ahead.
SPEKTRUM LiPo BATTERY & CHARGER
Adding to its value for RC boaters of all experience levels, the Sonicwake 24" Deep-V comes complete with a Spektrum 3S 3200mAh 30C Smart LiPo battery and S120 USB-C Smart battery charger. Safely recharging the battery is as simple as plugging the charger into any USB port and connecting the battery.
SPEKTRUM OUTRUNNER BRUSHLESS MARINE MOTOR
The factory-installed brushless power system included with the Sonicwake 24" Deep-V consists of a Spektrum 3542 2500Kv brushless outrunner marine motor paired with the Spektrum 50A brushless marine ESC. Together, they produce 35+ mph of spray-raising action.
BREAKAWAY RUDDER
BREAKAWAY RUDDER
Any RC boat is bound to have an accident eventually. When it happens, the rudder is usually the first part to bend or break. But the breakaway rudder of the Sonicwake 24" is designed to swing out if it strikes a solid object. That keeps it from breaking off of the hull and minimizes damage to the rudder itself. You don't even need to replace screws. Just push the rudder back into place and tighten it up!
SPEKTRUM SLT2 2-CHANNEL TRANSMITTER
The included 2-channel SLT2 2.4GHz transmitter offers everything you need for dependable, confident control. User-adjustable features include steering and throttle trims, steering rate, and throttle limits. All controls are positioned to be quickly accessible when needed and out of the way when not in use.
SSL (STRAP, SLIDE, LOCK) BATTERY INSTALLATION
No more struggling to secure the batteries in your boat hull's limited space. The Sonicwake 24" deep-V's SSL (Strap, Slide, Lock) system makes battery installation fast and hassle-free. Swapping out batteries is also quick and painless - you can be done and back on the water in just seconds.
BOAT STAND INCLUDED
BOAT STAND INCLUDED
Constructed of a sturdy composite, the included boat stand can be used for display or for working on your Pro Boat Sonicwake 24" Deep-V. Foam protects the boat's finish, and it can easily be used as a parts tray when needed.
OSE flex cable for ProBoat Sonic 24 for 3/16" props
1 of 2
Product ID ose-cable-sonic-24
Price$39.99
CNC High Pitched Aluminum Prop :  3/16 bore : 38 to 48mm
1 of 3
Product ID cnc-xx19250
Price$19.95
