ProBoat Blackjack 24" V2 : 4s Brushless Catamaran RTR
Discounts Apply !
Free Shipping on Select Items
Product ID hh-prb08049
List Price: $390.99
Price: $319.99
Blackjack 24" 4S Brushless Catamaran RTR
Free shipping while supplies last.
The long-running line of Pro Boat Blackjack ready-to-run catamarans experienced a major boost in performance and style when the large-scale Blackjack 42" was introduced in 2021. Among other upgrades, this big cat added Spektrum Smart technology to the highlights of the Blackjack design.
Now Pro Boat returns to where it all began, bringing the same improvements found in its "big brother" to the smaller, more affordable Blackjack 24". This redesigned Blackjack 24" not only looks better than the original but performs better as well.
Its brushless power system has been updated with top-of-the-line Spektrum electronics, including a Spektrum Firma 2200Kv brushless motor and Spektrum Firma 90A Smart ESC. The ESC is Smart ready, allowing you to receive vital telemetry data at your fingertips when using an optional Spektrum Smart receiver and transmitter. Straight out of the box, the Blackjack 24" is 4S capable. Just install the recommended batteries and you'll have all the speed and acceleration you can handle!
Other additions include the innovative Pro Boat SSL (Strap, Slide, Lock) battery tray that eliminates the hassle from locking down batteries in confined spaces. You can swap out packs in a snap – it takes only a matter of seconds. Bushing lubrication is simplified with a "grease and go" system that reduces this task to just three easy steps: remove the prop strut plug screw, pump in some grease, and seal it back up. The grease passes through the prop strut and stuffing tube into the bushing, right where it's needed.
Pro Boat gives you a choice of two iconic liveries for your Blackjack 24" catamaran. At top speed, the Heat Wave race livery is a blaze of wild color burning through the water. With the Blackjack offshore racing livery option, you'll feel like you're winning all of the aces in a power boat Poker Run.
With its brushless power, Spektrum electronics, and forgiving catamaran hull, the Blackjack 24" makes a great boat for everyone from first-timers to experienced modelers. If you're already a fan of the Blackjack 42", add this one to your collection and enjoy the same performance on lakes and ponds of almost any size, large or small.
The redesigned, ready-to-run Pro Boat Blackjack 24" comes with a Spektrum SLT2 2-channel 2.4GHz transmitter and boat stand for maintenance or display. Just add your own 4S battery setup (2x 2S 5000mAh) and compatible charger to race through the water with brushless-powered catamaran stability and speed.
Pro Boat Blackjack 24" V2 Features
  • Incredible styling and extreme 4S performance with 45+ MPH speeds
  • High-quality Spektrum radio and electronics
  • Ready to run – just add battery and charger
  • Heat Wave inspired bright and wild race livery option
  • Vegas offshore racing inspired Blackjack livery option
  • Fast, easy SSL (Strap, Slide, Lock) battery installation
  • Prop strut with easy-to-use "grease and go" bushing system
  • Damage-resistant break away rudder
  • Dual IC5 connector holders
  • Water-resistant receiver box
  • Adjustable, all aluminum hardware
SSL (STRAP, SLIDE, LOCK) BATTERY INSTALLATION
No more struggling to lock down batteries in your boat hull's limited space. The Blackjack 24" catamaran's SSL (Strap, Slide, Lock) system makes battery installation fast and hassle-free. Swapping out batteries is also quick and painless – you can be done and back on the water in just seconds.
"GREASE AND GO" PROP STRUT
The Blackjack 24" catamaran has a "grease and go" system that passes grease through the prop strut and stuffing tube into the bushing where it's needed. Just remove the plug screw from the rear of the prop strut, inject a few pumps of grease, and seal it back up. It's quick and easy!
EXTREME BRUSHLESS PERFORMANCE
Like its 42" long "big brother," the ready-to-run Blackjack 24" catamaran is designed for serious brushless performance. The boat comes equipped for 4S LiPo power right out of the box. Just install the recommended batteries and you'll hit speeds over 45mph right out of the box!
BREAK AWAY RUDDER
BREAK AWAY RUDDER
Any RC boat is bound to have an accident eventually. When it happens, the rudder is usually the first part to bend or break. But the break away rudder of the Blackjack 24" catamaran is designed to swing out if it strikes a solid object. That keeps it from breaking off of the hull and minimizes damage to the rudder itself. You don't even need to replace screws. Just push the rudder back into place and tighten it up!
Hitting the water with this offshore racing inspired Blackjack livery option is almost as exciting as being on a power boat Poker Run – and finishing with a royal flush.
DUAL IC5 CONNECTOR HOLDERS
The dual, hard mounted IC5 connectors work together with the SSL (Strap, Slide, Lock) system to simplify battery installation. You can easily slide your batteries into place and plug them in with one hand. The connectors also keep the wires secure and safe from potential hazards.
CLEAN COMPOSITE INTERIOR
The design of the Blackjack 24" catamaran's composite hull provides for a clean interior that keeps every wire, cooling line, and part right where it should be.
WATER RESISTANT RECEIVER BOX
When you're running on water, chances are good a small amount will get into the hull. Spektrum receivers are water resistant, but the exposed pins that accept servo leads are susceptible to connection issues if they do become wet. The Blackjack 24" catamaran includes a receiver box that locks out moisture and keeps this critical component safe and dry.
ADJUSTABLE HARDWARE
ADJUSTABLE HARDWARE
The all-aluminum hardware allows you to adjust the prop strut height and angle, so you can set up the Blackjack 24" catamaran to your liking and tune the boat to the water conditions.
SPEKTRUM SLT2 2-CHANNEL TRANSMITTER
The included 2-channel SLT2 2.4GHz transmitter offers everything you need for dependable, confident control. User-adjustable features include steering and throttle trims, steering rate, and throttle limits. The control layout is amazingly intuitive – all controls are perfectly positioned to be quickly accessible when needed and out of the way when not in use.
SPEKTRUM SMART READY
It's easy to upgrade your Blackjack 24" catamaran for Smart functionality. Telemetry capabilities are built into the included Spektrum Firma 90A Smart ESC. Pair it with your choice of Spektrum Smart radio and receiver, and the ESC can send vital telemetry to back to the radio – including RPM, voltage, cell voltages, and amperage.
3 Product Reviews - Average rating 4.3 / 5 (Show All)
The toy yorkie dog of boats
Steve S - 11th August 2025
Boat is like a happy little toy dog which bounces around when it barks. Straight line speed is good , but have to slow way down to turn. Nicely made, I run it stock with an abc 1614…go to ironclad rc and check out big b for a lot of good setup tips.
I read more
great value for the money
pedro ramos - 08th July 2024
great little boat, I'm still shocked how easy is to install or swap lipos, its just ridiculously easy.
Never mind is 4s! its agile and quick!
A definite hit for Pro Boat
undecided
J.Hathaway - 14th June 2024
Nice to see a boat with this many upgrades but wish it was a little longer maby like 30 or 32 inches.
Stuffing Tube Set : Blackjack 24" V2
Product ID hh-prb-1276
Price$14.99
Flex Shaft Set: Blackjack 24" V2
Product ID hh-prb-1277
Price$29.99
Canopy Thumbscrew Set : Blackjack 24" V2
Product ID hh-prb-1280
Price$19.99
Prop Strut Bushing : Blackjack 24" V2
Product ID hh-prb-1283
Price$11.99
SSL Battery Tray Set : Blackjack 24" V2
Product ID hh-prb-1286
Price$16.99
Stock Replacement Prop : Blackjack 24" V2
Product ID hh-prb282089
Price$20.99
Spektrum 2400Kv : 36 x 60mm 4 pole Brushless Marine Motor
1 of 3
Product ID hh-spmxmm1300
Price$69.99
Spektrum SR315 3-Channel DSMR Sport Receiver
1 of 3
Product ID hh-spmsr315
Price$39.99
