Pacer 5 Minute Epoxy
Product ID hh-pt36
In Stock 3
List Price: $7.99
Price: $6.99
Pacer epoxy adhesives cure and join things together by a chemical reaction between the resin and hardener. This reaction results in high strength bonds that are resistant to most chemicals. Use for household, industrial, crafts, or any job that require a high-strength, high-quality bond.
Best used on these materials:
-Metal & Wood
-Concrete
-Glass & China
-Ceramics
 Clear drying color.
Working time (time available to mix & apply product & position repair): 5 minutes.
Handling time (the amount of time repair should remain stationary for product to set): 15 minutes.
Full bond strength in one hour.
PSI strength: 1,500 pounds per square inch.
Water resistant.
It is not flammable.
 Working temperature range (once fully cured it can withstand this temperature range): -40 degrees to +176 degrees fahrenheit.
Du-Bro Epoxy Brushes
Product ID hh-345
Price$2.99
Du-Bro Mix-It-Stix (25)
Product ID hh-346
Price$2.65
Epoxy Mixing Cups (100)
Product ID hh-dlr925
Price$4.99
Fiberglass seam and parts mounting cloth 25mm wide
Product ID ose-80977-25
Price$1.49
Fiberglass seam and parts mounting cloth 50mm wide
Product ID ose-80977-50
Price$1.99
