Spektrum Soldering Jig
Product ID hh-spmx-1009
In Stock 2
List Price: $37.99
Price: $34.99
While soldering might not be every hobbyist's favorite task, we have developed this Spektrum Soldering Jig to make your life easier. This jig features an adjustable, movable alligator clip to hold the wire exactly where you want it. Both male and female ends of IC2, IC3, and IC5 connectors are embedded in this jig, so simply plug your connector in and solder away. Plugging your connector into the opposing-style connector prevents your connectors from warping due to heat or movement, allowing you to solder with unmatched precision. As a bonus, this also holds 2.0mm to 7.0mm bullets for easier soldering.
  • Allows for easier soldering of IC2, IC3, IC5, and bullet connectors.
  • Unique design makes convenient work of all your soldering needs.
  • The “Helping Hand” arm clamp makes precise soldering easier.
  • Composite base with rubber feet for added stability. Includes both male and female IC connectors.
  • Helps prevent connector warp when soldering.
« Previous | Next »
Hot Racing Plug/Connector Soldering Jig
Product ID hh-sd488E
Price$22.99
Weller - Heavy Duty 80 Watt Soldering Iron with LED Halo Ring, 120V, 880F
1 of 3
Product ID ama-WLIR8012A
Price$34.95
