Firma 200A Smart Brushless Marine ESC : Upto 12s
Discounts Apply !
Free Shipping on Select Items
Product ID hh-spmxme1200
In Stock 1
List Price: $287.49
Price: $239.99
Firma 200A : 6s to 12s : Smart Brushless Marine ESC with IC5 (EC5 Compatible) battery connectors and Castle 8.0mm Connectors for the motor.
Overview
Feature-packed Spektrum® Firma™ Smart ESCs deliver power and intelligence all-in-one, with no additional modules or links required. Capable of a 1200 Amp burst current, the waterproof Firma 200A Smart Brushless Marine ESC powers your boat through almost any condition imaginable, with explosive acceleration and ultra-smooth performance – while feeding real-time telemetry straight to your Spektrum® transmitter! Additionally, the dual IC5's provide flexibility in running 3S-6S batteries. The Smart data wire on the innovative IC5™ connector replaces sensors, sending telemetry information to a compatible Spektrum transmitter directly from the Firma™ Smart ESC.
Features
  • Smart all-in-one telemetry
  • Fast, powerful 32-bit ARM M4 processor
  • Water-cooled for maximum performance
  • Waterproof*
  • Multiple programming options
  • Multi-point protection
Spektrum® Smart Electronic Speed Controls Overview
WATERPROOF
The Firma Marine ESCs are extensively designed and tested to provide a water-tight seal when run in nearly any fresh water environment. Perfectly suited for RC boat applications in a large range of sizes and capabilities. Please note it is not recommended to run in salt water and ocean shore environments.
EC5® BACKWARDS COMPATIBLE
Firma® ESCs feature IC® series battery connectors. The IC series of connectors are designed from the ground up to provide a more solid connection, higher heat resistance, and effortless installation. When used with an or IC5® connector-equipped Spektrum® Smart battery, the ESC can receive and transmit battery telemetry data. EC5 are also compatible with Firma ESCs for basic operation and ESC telemetry.
ONE-WIRE TELEMETRY
No need to connect multiple wires, sensors, modules, and links. With Firma® ESCs, simple one-wire telemetry transmits a wide range of data directly to your transmitter in real time, including RPM, voltage, temperature, balance, and capacity used*
           *See compatibility chart for more information.
 SMART TECHNOLOGY BATTERY DATA
When used with a Spektrum® Smart LiPo battery, your Firma® ESC provides you with the benefit of battery telemetry that's automatically transmitted to your compatible Spektrum radio in real time. On your transmitter screen you'll be presented with helpful information such as number of cycles, battery capacity used and remaining, individual cell voltage and more!
 MULTIPLE PROGRAMMING OPTIONS
Multiple programming options are available. Button programming can be used with nothing more needed. Using the Smart Firma® ESC Programming Box, you can easily change settings at the track to suit driving conditions. An easy-to-use Smart Link USB Updating and PC Programmer app is also available.
Loop Connector: IC5
Product ID hh-ara390292
Price$7.99
Spektrum 4685 4 pole Brushless Marine Motor 740kv
1 of 2
Product ID hh-spmx-1075
Price$129.99
