Leopard 4074 Motor
Product ID leo-4074
List Price: $94.95
Price: $79.95
Leopard 4074 Motor.
40mm Diameter by 74mm Long Brushless Motor by Leopard Power. Hand-wound for high efficiency of up to 90%.
Includes a water Jacket with Leopard Motor Purchase!
Comes with high-quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance.
We offer this in 6 versions.
1050 Kv/rpm per volt
1400 Kv/rpm per volt
1650 Kv/rpm per volt
1800 Kv/rpm per volt
2000 Kv/rpm per volt
2200 Kv/rpm per volt
Specs:
Magnets: neodymium
Watts: 1500 with Over 2800 Burst.
Poles: 4
Motor Shaft: 5mm with a flat spot
Can Measures: 40mm diameter x 74mm long
Weight: 375 Grams
Mounting screw diameter required: 3mm
Bearing size: 5mm wide x 16mm OD x 5mm ID
Mounting holes 25 mm apart for use with most 540 mounts.
Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your ESC connection.
OSE suggests 20,000-35,000 total rpm for boats. We suggest that most Fast Electric Boaters should run in the 25,000 RPM range for sport boating or the 30,000 RPM range for racing. These are only guidelines; if you don't know how to choose the correct motor, please consult other members of the RC fast electric boating community or us either at a local club or on our OSE Forums.
4 Product Reviews - Average rating 4.8 / 5 (Show All)
Suitable for RC Drag boats
Paul Goddard - 29th February 2024
I put 2 of these on the old styrene Berkely jet drive OSE used to sell. This is of course WAY TOO MUCH MOTOR! Belt drive through reduction gear with 1/4" ball bearing. I reinforced the body and jet cup for strength, just looks really on the jet curead more
Leo motors fit the bill.
Kurtis Ruegg - 31st October 2017
I have an old school Dumas Deep Vee 40 fiberglass hull and had a Hobbyking 4084 1050 kv with a CNC 54mm prop, HK 180a ESC on 6s 5000mah.
I"d get about 5 min run time and about 45 mph top speed. Not bad at all for this heavy beast!
I switched to aread more
4074 2000kv - Remarklable motor
amisol - 08th August 2017
I have leo 4074 2000kv, 6s and seaking 180a in a 32" TFL Pursuit. Prop is cnc 1445. Speed approx. 62.5 mph. NO heat issues at all after 15 x 8 minutes tests. This motor is perfect
Good motor
Robin Ducker - 17th February 2017
One of the best. Put some BOCA bearings in and they purr. Great ability to rev and even the 2200KV can accept 6S for a while.
**** Response from Offshore Electrics Inc. ****Thanks for the rating. The 2200kv with 6s is only for short use, 1-3 seconds inread more
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
T-Jet Large Jet Drive by TFL
1 of 6
Product ID tfl-B54270
Price$279.99
Carbon fiber heavy duty motor mount for 40mm motors.
1 of 3
Product ID tfl-523b67-carbon
Price$19.99
Rear motor mount clamp ring
1 of 4
Product ID ose-80600-RC
Price$6.99
Rear clamp motor mount for 36mm or 40mm Motor
Product ID ose-83005
Price$9.95
Leopard 4050 Motor Water Jacket
Product ID leo-4050-jacket
Price$12.95
