Retaining Glue Loctite 603
Product ID mc-loc603
In Stock 0
Price: $21.99
Loctite 603
This product is a high strength retaining glue that is used to glue a flex cable into propeller shafts. This is thinner than Loctite 638, made for tighter fitting parts.
Type: For Oily Parts
Begins to Harden: 10 min.
Reaches Full Strength: 24 hrs.
Temperature Range: -65° to 300° F
Fills Gaps Up To: 0.005"
Color: Green
Additional Specs: For Close-Fitting Parts
Secure unthreaded metal cylindrical parts such as shafts, hubs, bearings, bushings, splines, pulleys, and press-fit assemblies. Retaining compounds prevent corrosion and fluid leaks and resist most chemicals. Primer is recommended when working with aluminum, black-oxide finishes, cadmium, stainless steel, titanium, and zinc.
 .34 fl. oz Bottle. Enough to assemble a couple of dozen cable and prop shafts.
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
Recently Viewed
Pick up where you left off.
