Retaining Glue Loctite 638
Product ID mc-loc638
In Stock 0
Price: $24.99
Loctite 638
This product is a high strength retaining glue that is used to glue a flex cable into propeller shafts. The product is thicker than Loctite 603 and Loctite 648. Made for fitting parts with a larger gap.
Type: NSF Certified
Begins to Harden: 4 min.
Reaches Full Strength: 24 hrs.
Temperature Range: -65° to 350° F
Fills Gaps Up To: 0.01"
Color Green
Additional Specs: For Loose-Fitting Parts
Secure unthreaded metal cylindrical parts such as shafts, hubs, bearings, bushings, splines, pulleys, and press-fit assemblies. Retaining compounds prevent corrosion and fluid leaks and resist most chemicals. Primer is recommended when working with aluminum, black-oxide finishes, cadmium, stainless steel, titanium, and zinc.
 .34 fl. oz Bottle. Enough to assemble a couple of dozen cable and prop shafts.
High performance Sevan Outboard
1 of 5
Product ID bel-flex-2042
Price$169.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
