Octura .130 cable system for 1/8" props
Product ID oct-oc64pkg
In Stock 3
List Price: $14.25
Price: $12.99
Octura .130 flex cable and 1/8" prop shaft for 1/8" props.
The shaft is 3/16" with the prop end measuring 1/8" to fit the smaller props. This option is good for high-powered boats in the 20" (500mm) range that need the strength of larger cables and prop shafts.
Unassembled, requires attaching the shaft to the cable with solder or glue. We also offer these assembled in the Flex cable assemblies category, click here.
Specs:
18" in length end to end
.130 flex cable
.130 teflon liner
3/16" to 1/8" turned down prop shaft oct-oc64pkgps
drive dog pn# oct-oc4d
blass bullet nut pn# oct-oc4pn
