Octura hardened steel Bullet Nut for 3/16" shaft (10-32 thread)
Product ID oct-oc6pnm
In Stock 12
Price: $3.49
Octura large diameter 3/8" steel bullet nut for 3/16" (4.75mm) shaft with 10-32 thread.
Stream line your drive system for maximum performance with this tapered bullet propeller nut. This is the large diameter nut for propellers with larger 3/8" hubs.
These fit most 3/16" prop shafts that have 10-32 threads. For example, AeroMarine, Octura, Hughey, OSE, Speedmaster and many more of 3/16" Prop Shafts made in the USA.
Please double check the thread size of your shaft.
In some cases manufacturers will use a US sized 3/16" shaft with 4mm Metric threads.
For example, AquaCraft SuperVee, Ul1 and Revolt
Contains bullet nut only (propeller & shaft not included).
Octura 3/16" prop shaft for .130 flex cable
Product ID oct-oc6130ps
Price$4.99
Octura 3/16" prop shaft : 2.25" : for .150 flex cable
Product ID oct-oc6150ps
Price$5.49
Octura 3/16" Long prop shaft : 3" : for .150 flex cable
Product ID oct-oc6150psL
Price$4.99
Propeller Shaft 4.25" Long (3/16"Dia) & Drive Dog
1 of 2
Product ID oct-oc6psL
Price$7.99
Octura 3/16" Prop shaft for .062 piano wire: 2.25" Long
Product ID oct-oc6062ps
Price$5.49
Octura 3/16" Prop shaft for .062 piano wire: 3.00" Long
Product ID oct-oc6062ps-L
Price$5.49
Octura 3/16" Prop shaft for .078(2mm) piano wire: 3.00" Long
Product ID oct-oc6078ps-L
Price$5.79
Octura 3/16" Prop shaft for .078(2mm) piano wire: 2.25" Long
Price$5.49
