Brass Flex Ferrules: 1/4" shaft to 1/4" Cable
Product ID oct-ocfsf2525
In Stock 2
List Price: $4.99
Price: $4.59
Brass Flex Ferrule: 1/4" Shaft to 1/4" Cable
This can be used with oct-oc68ps
Specs:
- Outer diameter:  1/4" (6.375mm approx)
- Length: 1.4" (35.5mm approx)
This is used when connecting a round 1/4" flex cable to a 1/4" propeller shaft. The cable can either be glued or soldered into the flex ferrule. You can read some info on the glue method here. The opposite end uses 2 grub screws to tighten the shaft to the flex ferrule.
Octura 1/4 (.250, 6.35mm) Left Lay Cable : One Square End
1 of 2
Product ID oct-oc8sq-L-24a
Price$7.99
Octura 1/4 (.250, 6.35mm) Right Lay Cable : One Square End
1 of 2
Product ID oct-oc8sq-R-24a
Price$7.99
Octura 1/4" (6.35mm) to 3/16" (4.75mm) Shaft
Product ID oct-oc68ps
Price$12.99
