Brass Flex Ferrules: 3/16 shaft to 3/16 Cable : 3/8 OD
Product ID oct-ocfsf616
In Stock 2
List Price: $4.99
Price: $4.59
Brass Flex Ferrules: 3/16" shaft to 3/16" Cable
Specs:
- Outer diameter:  3/8" (9.5mm approx)
- Length: 1.2" (30.2mm approx)
This is used when connecting a round 3/16" flex cable to a 3/16" propeller shaft. The cable can either be glued or soldered into the flex ferrule. You can read some info on the glue method here. The opposite end uses 2 grub screws to tighten the shaft to the flex ferrule.
