Fiberglass Filled 3 Blade Propeller
Product ID ose-3bld-316
Price: $2.49
These are fiberglass-filled plastic propellers. Adding fiberglass makes them more rigid/stronger than a propeller made only of plastic. These are a low-cost alternative to metal boat propellers. These don't need to be balanced or sharpened.
 OSE Glass Filled 3-Blade 3/16" Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
ose-3bld-316-4747 mm (1.85")65.82.593/16"
ose-3bld-316-5252 mm (2.05")72.82.873/16"
ose-3bld-316-5555 mm (2.17")77.03.033/16"
ose-3bld-316-5757 mm (2.24")79.83.143/16"
Specifications:
  • Pitch ratio: 1.4
  • Blades: 3
  • Material: Glass-filled reinforced plastic
  • Mounting: 3/16" (4.75mm) Drive dog
  • We recommend these for the 10K-25K RPM Range.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
