Aluminum medium-sized pair of left and right turn fins for a deep vee or mono hull. The mounting brackets on these make them very adjustable. They can be moved up and down or tilted into or away from the transom. Brackets are constructed of aluminum. Fin Measures 68mm tall x 25mm wide x 2mm thick. These come with everything in the picture, plus some basic mounting bolts and nuts.
Pick up where you left off.
