Carbon, Water cooled heavy duty motor mount for 36mm motors.
Product ID ose-80210
In Stock 8
List Price: $22.95
Price: $15.95
Carbon, Water-cooled heavy-duty motor mount for 36mm motors.
Fits 36mm diameter motors that are 60mm or longer in length.
Water-cooled and adjustable. The rear motor clamp helps carry the weight of the heavier/longer 36mm motors. The angle is adjustable to allow straight alignment with flex cable.
The anodized aluminum mounting plate with extended Carbon Fiber mounting stands distributes the weight of the motor over a larger area for added strength. The mounting plates have holes drilled in the bottom to allow the epoxy to flow into them to make a superior bond to the hull. This mount can fit a flat mounting area like a rigger or hydro, or a deep vee.
Applications:
Fits most 36mm motors that are 60mm or longer.
For example Feigao, Nemesis, Hacker 540XL motors. Tp36xx, Leopard 3660, 3674
Will fit up to a 50mm long water jacket.
Measures:
Total width of 58mm including the mounting stands.
Metal center mounts measure 53mm wide.
Requires you to provide motor mounting screws.
Comes with a mount only. Motor and water jacket only in pictures for display purposes.
36mm Quick Change motor adapter for 36mm diameter motors
Product ID tfl-523b46a-bk
Price$16.99
40mm Quick Change motor adapter for 40mm diameter motors
Product ID tfl-523b47a-bk
Price$16.99
