Servo Controlled Tab Assembly Large Sized
Product ID ose-80910
In Stock 6
Price: $49.95
Servo-controlled adjustable trim tab assembly. Picture 3 shows the CAD drawing of the tabs installed.
Large size for boats in the approximate 35"(900mm) plus length range(depending on transom width).
Each tab measures approximately
50mm( 1.97") wide x 50mm (1.97") deep x 28mm (1.1") tall.
(2) tabs per pack.
Includes everything in the picture. No linkage or servos included.
*Note: The picture shows the item measured in inches.
2 Product Reviews - Average rating 4 / 5 (Show All)
great item
Jason - 27th October 2017
Worked well in my boat. Now I need to make it faster.
Well designed but room for improvement
Fella1340 - 10th October 2015
I was very impressed when I recieved the trim tabs. Very clever design for trim tab movement. You need to be very gentle when snugging up the threaded brass bushing. The wall thickness is only 0.010" thick. I learner the lesson the hardware and had tread more
