56mm Motor Mount Aluminum & Carbon
Product ID ose-80974-v3
In Stock 0
Price: $49.95
Adjustable 56mm Motor Mount. This works well in a deep vee / mono style hull. Now features Carbon fiber stands with glue holes in the mount, which adds extra surface area to improve mounting.
Note: Fits motors that are 56mm diameter x 80mm or longer. If your motor has screws outside of the case, check measurements in picture 7.
Examples
Leopard 56mm motors, 5692, 5698 and 56110
TP Power v1 motors, Tp5660, TP5670 and TP5680
TFL-SSS 56mm Motors
The integrated top plate can be used to mount an ESC. All Aluminum construction.
Note: Works with water jackets up to 70mm long.
Install Note: The center metal section measures 4" wide, so the center two metal parts can be used in hulls with 4" wide rails if needed.
Tenshock Evo 2880  (53mm x 119mm long)
1 of 5
Product ID ten-evo-2880
Price$395.99
