Mini OutBoard
Product ID ose-80980
In Stock 14
Price: $89.99
Mini OutBoard Motor.
This is a complete outboard unit with mounting brackets and 3000kv outrunner motor for 2s Lipo applications. It can be used with 3s lipo power with a light weight hull in the sub 1 pound range. The propeller in this outboard is CNC Aluminum and driven by a flex shaft, making it smooth and efficient. The all aluminum lower unit makes for a strong, yet light weight
This outboard will require an esc, we suggest the OSE Raider 90 esc. You will have to buy and solder 3.5mm connectors onto the esc to mate them together.
Specifications:
Brushless Outrunner Motor 3000kv with male 3.5mm male bullet connectors.
32mm Diameter CNC aluminum prop.
1/8" (3.175mm) propeller shaft.
Will fit upto a 36mm diameter propeller.
Carbon Fiber trim plate.
Water pickup with included water cooled motor mounting plate.
Weighs less than 7 ounces.
This will fit 1 pound boat hulls in the 22" (550mm) to 25" (620mm) Range. If you have any setup questions please email before purchase.
Requires:
7/32" water tubing.
Female 3.5mm bullet connectors pn# hh-gpmm3113
2x Linkage rod fittings pn# ose-83119
4 Product Reviews - Average rating 4.5 / 5 (Show All)
Scale looks
Trey - 17th June 2025
I use this on deep vee I 3d printed. I like the scale look with decent performance
Good product but
R. Brent - 25th May 2025
I installed one of these outboards on my old MRP Bud Light tunnel hull and was more than quite pleased with the results untill on the third run the outer portion of the flex shaft failed right at the connection to the prop shaft. Hoping that the replacemread more
Great little outboard
Dominator - 13th February 2025
I put two of these on a small 24 cat. On 2s it rips with long runtime. I used the seaking 60 esc's and they ran ok, but swapped to raider 90 esc's and its running much cooler now.
Great beginner motor
Bomber - 04th July 2023
Easiest install ever put on the delta force mini storm paired with spectrum 100 amp marine esc. Plenty fast enough for the beginner and puts a smile on the seasoned boater. Total head Turner
« Previous | Next »
Linkage Rod Boots Medium
1 of 2
Product ID ose-80452
Price$2.95
OSE 3.5mm Bullet Connectors
Product ID ose-3.5mm-bullet
Price$0.89
Outrunner Brushless Motor
1 of 4
Product ID tfl-F450B-KV3000
Price$22.95
OSE Raider 6s 90amp Esc with Ec5 connectors
1 of 2
Product ID ose-R-90
Price$49.99
Linkage Rod Connector for 2.5mm Rod
1 of 2
Product ID ose-83119
Price$2.49
Replacement Mini OutBoard Cowl/Cover
1 of 4
Product ID ose-80982
Price$12.95
Flex Shaft assembly for OSE Mini Outboard
Product ID ose-80981
Price$9.99
Teflon Liner for TFL Outboard ose-80980 / tfl-542b20
1 of 2
Product ID tfl-212b15
Price$3.99
Bushing for OSE Mini Outboard
Product ID ose-80983
Price$9.95
