OSE Stuffing tube mount with oil fitting
Product ID ose-83010
Price: $14.95
OSE carbon-fiber stuffing tube mount with fitting for oiling your cable.
Carbon fiber stands and an aluminum center section. The carbon stands have glue holes for secure mounting to the inside of your hull and two long slots for adjusting the height of the stuffing tube. The aluminum stuffing tube holder can also be angled
Comes in 3 sizes
ose-83010-7/32 for K&S 7/32 stuffing tube.
ose-83010-1/4 for K&S 1/4 stuffing tube.
ose-83010-5/16 for K&S 5/16 stuffing tube
Install notes:
Drill a 4mm hole in the stuffing tube in the area where you want to install the mount before attempting to tighten the screws on the mount. Do not over-tighten the screws on the mount. Over-tightening will strip the mounts. We also recommend using silicon sealant between the mount and stuffing tube to ensure a good seal and prevent leaks. The oiler will NOT work with a stuffing tube system that uses a Teflon liner.
Picture 2 shows all three stuffing tube sizes. Note that all the mounts are identical, only the center hole for the stuffing tube is different.
TFL 1/4 Drive
1 of 4
Product ID tfl-503b98
Price$79.99
TFL 1/4 Inch Drive with skeg
1 of 4
Product ID tfl-503b98-a
Price$79.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
OSE Carbon Stuffing Tube Mount
1 of 2
Product ID ose-83029
Price$3.95
