OSE Dual Quick Change Motor Mount
Product ID ose-83255
In Stock 1
Price: $49.99
OSE Dual Quick Change 40mm Motor Mount
Designed similarly to our 40mm Single Quick Change Mount, this mount allows for twin motors with the quick-change motor clamp feature to easily remove the motors without having to fight to remove the front motor screws. The mount is also constructed of CNC Aluminum Front and Rear Mounting Plates, as well as 3 mm-thick Carbon Fiber Side Rails, to withstand the force of two motors. Features two front quick-change motor clamps (ose-83351).
Can be used in a Mono or catamaran-style hulls. The aluminum front and rear clamps are 5" wide to fit standard nitro/gas boat hulls with 5" wood rails—for example, Delta Force Hulls. Can be used with any 40mm motor such as: Leopard 40series; TP 40series; SSS 40series; Neu 15 Series
Includes:
(2) 3mm Carbon Side Rails
(2) Silver anodized aluminum front and rear mounting plates
Specs:
Length: 110mm (4.33")
Width: 135mm (5.31")
Height: 50mm (1.96")
Weight: 99g (3.5 oz)
Center to center of motor shafts: 70mm (2.76")
Video of Quick Change Feature.
OSE Quick Change Motor Mount, for 4 Bolt Motor Plate
1 of 4
Product ID ose-83350
Price$29.95
Front 4 hole pattern clamp for OSE Quick Change Mount
1 of 2
Product ID ose-83351
Price$8.95
OSE Quick Change Motor Mount, for 6 Bolt Motor Plate
1 of 4
Product ID ose-83354
Price$29.95
Front 6 hole pattern clamp for OSE Quick Change Mount
1 of 2
Product ID ose-83355
Price$8.95
