OSE Strut for Traxxas M41 to convert to 3/16": Strut Only
Product ID ose-83274
Price: $19.95
OSE Traxxas M41 Catamaran 3/16" Propshaft Strut Upgrade for use with 3/16" (.187", 4.75mm) Prop Shafts.
Available in blue or silver color.
Note: This will not work with the stock M41 Cable!
-Upgrade your Traxxas M41 Cat to a much stronger 3/16" (.187", 4.75mm) cable and shaft system.
-Works in the stock Traxxas Stuffing tube.
Traxxas built the M41 with a 5mm propeller shaft and .150 cable. This limits the power you can use. Most power increases cause the stock cables to twist and break.
We built this strut in standard 3/16" size and included two installed lead Teflon bushings (part# oct-oc6ltsb) for added prop shaft support. This strut is an absolute must for customers running modified motors with their M41's.
Includes:
OSE M41 strut ONLY. Includes two installed oct-oc6ltsb lead Teflon bushings.
Requires:
OSE-187L Cable
OSE-81518 Coupler
OSE High Power Cable System for Traxxas M41
1 of 3
Product ID ose-cable-system-m41
Price$59.95
OSE Heavy Duty upgraded Traxxas m41 HD Cable
Product ID ose-cable-HD-m41
Price$39.99
