OSE Quick Change Motor Mount, for 6 Bolt Motor Plate
Product ID ose-83354
In Stock 14
Price: $29.95
40mm Quick Change Mount, designed by Anthony Vaccaro.
Designed to speed up swamping of a motor during a race or if your just tired of trying to remove the front screws on your motor for maintenance.
Once the coupler is loosened, the motor can be removed in less than a minute. Normally racers would have to remove the front screws which could take a few minutes and more importantly, once a motor is removed in a conventional mount, the motor angle has to be realigned. With only 4 screws the motor is removed, while maintaining the motor angle. Also features clear access to the front motor vents to allow maximum cooling. See video for a quick change.
Material:
Carbon fiber stands
Aluminum cnc motor brackets.
Measures:
62mm wide (not including protruding screws)
110mm long
Motor applications:
Motors with 6 Bolt front motor plates, Tested to work with Tp or Neu 6 Bolt Front plate 40mm Motors.
Requires: You to provide motor mounting screws.
 Includes: Mount in picture 1
1 Product Reviews - Average rating 5 / 5 (Show All)
Quick change motor mount
John Finch - 18th August 2026
I have changed out all my motor mounts for this unit. They are the bomb! So easy to install and when changing motors it is quick and easy. Shaft alignment is always right on target.
OSE Quick Change Motor Mount, for 4 Bolt Motor Plate
1 of 4
Product ID ose-83350
Price$29.95
Front 4 hole pattern clamp for OSE Quick Change Mount
1 of 2
Product ID ose-83351
Price$8.95
Front 6 hole pattern clamp for OSE Quick Change Mount
1 of 2
Product ID ose-83355
Price$8.95
OSE Dual Quick Change Motor Mount
1 of 5
Product ID ose-83255
Price$49.99
