OSE Quick Change 5" Rail Motor Mount, for 56mm Motor with 6 bolt pattern.
Product ID ose-83403
In Stock 4
List Price: $49.99
Price: $44.99
Designed to speed up the swamping of a motor during a race or if you are just tired of trying to remove the front screws on your motor for maintenance. The rear motor clamp uses a rubber O-ring to stabilize the motor, allowing motors with slight diameter variations to fit in the same clamp.
Once the coupler is loosened, the motor can be removed in less than a minute. Usually, racers have to remove the front screws, which can take a few minutes, and, more importantly, once a motor is removed from a conventional mount, the motor angle has to be realigned. With only four screws, the motor is removed while maintaining the motor angle. Also features clear access to the front motor vents to allow maximum cooling.
Specs:
Aluminum CNC motor brackets.
Width: 5" (approx 127mm)
Motor mounting hole: For 4mm screws
Motor hole spacing: 30mm on center
Motor applications: Works with all 56mm Motors with a 6 Bolt front motor plate, tested to work with TP Power or SSS 56mm Motors.
Requires: m4 Motor mounting screws. The mounting plate is 5mm thick. Normally, a 10mm long screw can be used. Make sure to use a short enough screw so it doesn't hit the windings.
Includes:
- Mount shown in picture 1
- 5mm diameter mounting screws for mounting to your rails
- (1)  o-ring 3mm wide x 51mm od pn# 9262K751
OSE Quick Change 5" Rail Motor Mount, for 56mm Motor with 4 bolt pattern.
1 of 6
Product ID ose-83401
Price$44.99
SSS 56104 V2 Brushless Motor
Product ID tfl-sss-56104-v2
Price$169.99
SSS 56114 V2 Brushless Motor
Product ID tfl-sss-56114-v2
Price$184.99
SSS 56123 V2 Brushless Motor
Product ID tfl-sss-56123-v2
Price$199.99
Delta Force DF90 MK-ll: Bare Hull (49.5" 1250mm)
1 of 6
Product ID df-df90-mk-ll
Price$399.99
Motor Mounting Orings for Ten Shock 2880 Motor
1 of 2
Product ID mc-9262K823
Price$1.49
