RC Boat Water Pump 3-6V 370 Water Cooling Pump w/ JR Plug for RC Vehicles
Product ID ose-83416
In Stock 0
List Price: $9.95
Price: $7.99
This pump will work off of the voltage supplied to your receiver. This is simply plugged directly into an open spot on your receiver. The JR style plug will work with most modern receivers on the market.
Features:
- At 5V, the pump will still operate normally after 15 hours of operation without interruption.
- Low Noise: The low noise design gives you the perfect experience.
- The 370 motor water pump is suitable for installation on a remote-controlled boats that requires water cooling for the water-cooled motor or ESC. The pumping voltage of the 370 motor is 3 to 6V, which can be directly plugged into the receiver for power.
- Suitable for remotely controlled aircraft carriers, warships, battleships, and other vehicles that require water cooling for electric motors and ESCs.
- Water pump working test: After actual testing, the water pump works continuously for 15 hours under the condition of 5V voltage, and the pump will work normally. The temperature will be hot, but it is in the normal range and will affect the use.
Specifications:
- Voltage from 3 to 6 volts
- Voltage: 3 V Pumping flow: 1.1L / one minute Pumping flow: 300ml / one minute
- Voltage: 6 V Pumping flow: 1.8L / one minute Pumping flow: 600ml / one minute
- Pump & motor length: 60mm
- Pump & motor length including the tubing fittings: 72mm
- Diameter: 28mm
- Wire length: 200mm
- Weight: 72 grams
Note: Works with OSE 7/32", 1/4", 9/32" and 8mm Tubing. Zip ties are recommended with all tubing, but required for use with 1/4" and 8mm tubing to tighten the tubing to the fittings.
3 Product Reviews - Average rating 4.3 / 5 (Show All)
moves lots of water
Jean LaFrance - 05th September 2024
this pumps moves the water in the cooling tube very quickly, helps cool my rtr boat
these work great for high speed runs
Mark G - 16th July 2024
Ive used these on a 3rd channel to cool the system after a high speed run.
Overall Happy
Thomas Piening - 10th July 2024
Works really well for my application, would have been 5 stars except one of the leads needed resoldered when I received it.
Zip Ties : Black : 25 pack
1 of 3
Product ID ama-ziptie
Price$0.99
OSE 8mm od x 4mm id tubing : 3' (900mm) long
1 of 13
Product ID mo-color-tub-8mm
Price$6.99
OSE Medium 7/32" Silicone Tubing
Product ID ose-tubing_7-32_clear
Price$3.49
OSE Large 1/4" Silicone Tubing
Product ID ose-tubing_1-4_clear
Price$3.99
OSE Extra Large 9/32" Silicone Tubing
Product ID ose-tubing_9-32_clear
Price$4.49
