OSE Raider 6s 90amp Esc with Ec5 connectors
Product ID ose-R-90
In Stock 16
List Price: $79.99
Price: $49.99
OSE Raider 90 ESC for 2s-6s. Plug-and-play with the popular-size connectors already installed for use with Leopard 3650 motors. Dual cooling tubes for superior cooling.
Sale $49.99 while supplies last.
What makes ours better than the rest.
- Preinstalled 6mm Bullet connectors on the motor end and EC5 for the battery ends.
- Longer motor wires for use in more applications.
- And most importantly, after-sales service within the USA. Instead of having to return things to China.
We made this super easy to install. We install 6mm female bullet connectors on the motor side. This allows a plug-and-play ESC when combined with the Leopard Motors we sell (contact us if in doubt about your setup). We then install an EC5 connector for the Battery End.
This ESC is specially designed for use in RC boats.
-Excellent waterproof design allows this ESC to work in wet conditions.
-Optional LED Program Box for easy setting of all the esc's parameters.
-Low voltage protection.
-Thermal protection, if esc goes over 100C (212F) the output will reduce to and not return to normal until the temperature reaches 80c (176F) or less.
- Built-in BEC (battery eliminator circuit) to power your receiver.
-Throttle signal loss protection.
-Programmable for Forward and Reverse or Forward only.
 Specification:
-Continuous Current: 90 Amps
-Peak Current: 500 Amps. This is only for a brief second or so.
-Wire size: 12 Gauge
-Input: 2-6S (7.4volts - 22.2volts) Lipo
-BEC Type: Switch Model
-BEC Output: 5.5V/5A
-Water cooling fittings: 5mm threads.
-Weight: 120 Grams
-Size (excludes the Water Cooling Pipe): 57mm X 50mm X 17mm
Click here for full esc manual.
Click here for program box manual.
Includes:
(1) OSE Raider 90 Esc
(3) Installed OSE-6Bullet connectors soldered onto the ESC motor wires.
(1) Installed EC5 connector soldered onto the ESC battery end.
Suggested use in 22" (500mm) to 28" (700mm) planing hulls with a weight in the 1 to 2 pound range.
3s system, Raider 90 with Leopard 3650 2450Kv Motor
4s system, Raider 90 with Leopard 3650 2090Kv Motor
6s system, Raider 90 with Leopard 3650 1480Kv Motor
This ESC is suggested for smaller boats in the 20" (500mm) to 30" (750mm) range. Because there are so many variables with each hull and installation, it's impossible to specify all the applications for this ESC. If you have any questions on using this ESC with your particular boat, please contact us before purchase.
Note: This ESC was designed to work in an environment where it may get wet on occasion. Not for use underwater. OSE does not suggest using this item underwater!!
1 Product Reviews - Average rating 5 / 5 (Show All)
the perfect esc for a 24" boat like the blackjack
Outboard man - 26th April 2023
I have used these with 2s to 4s in 28 to 36mm motors, in outboards. I used one to replace the small 30 amp esc in the blackjack 24.
Mini OutBoard
1 of 6
Product ID ose-80980
Price$89.99
Scale Outboard with Metal Lower Unit: All Black
1 of 3
Product ID bel-2041-alu
Price$199.99
Leopard 3650 Motor
Product ID leo-3650
Price$44.95
OSE EC5 Parallel Harness
Product ID ose-ec5-parallel
Price$9.99
OSE EC5 Series Y Harness
Product ID ose-ec5-series
Price$10.99
OSE 6.0mm Bullet Connectors
Product ID ose-6mm-bullet
Price$1.65
Programming Card for OSE Raider Esc's
1 of 2
Product ID ose-R-box
Price$9.99
TFL P1 Drive System with 2960 Motor
1 of 6
Product ID tfl-b42515
Price$219.99
Charge Lead for EC5 Connectors
Product ID ose-ec5-chrg
Price$6.95
EC5 Male Connector by E-flite
Product ID hh-eflaec501
Price$7.99
EC5 Female Connector by E-flite
Product ID hh-eflaec502
Price$7.99
EC5 Connector
1 of 3
Product ID ose-ec5
Price$1.50
