OSE assembled .150" flex cable with Octura 3/16" stepped down to 1/8" Shaft for 1/8" propellers. The shaft is made for 3/16"(.187') struts. The propeller shaft measures 2 1/4" long(approx 57mm) Measures approximately 24"(approx. 610mm) from tip to tip.* The Includes: Octura oct-oc61504ps Shaft Octura oct-oc4d brass drive dog. Octura oct-oc4pn Bullet Prop Nut .150 Teflon Liner.
Requires:
Pick up where you left off.
