OSE .150 reversed (right) cable with 3/16" to 1/8" stepdown prop shaft
Product ID ose-cable-1075-R
In Stock 5
Price: $29.99
OSE assembled .150" Right flex cable with Octura 3/16" stepped down to 1/8" Shaft for 1/8" propellers.
The cable in this package is made for propellers that spin clockwise. For example, Octura props that end in the letter "R" or Graupner props that end in the letter "L".
The shaft is made for 3/16"(.187') struts.
The propeller shaft measures 2 1/4" long(approx 57mm)
Measures approximately 24"(approx. 610mm) from tip to tip.*
The Includes:
Octura oct-oc61504ps Shaft
Octura oct-oc4d brass drive dog.
Octura oct-oc4pn Bullet Prop Nut
 .150 Teflon Liner.
Requires:
  • 1/4 OD K&S brass tubing for stuffing tube when used with the Teflon liner.
  • Cable cut to your desired length.
OSE .150 cable with 3/16" to 1/8" stepdown prop shaft
Price$29.99
