OSE .130 cable with 4mm prop shaft
Product ID ose-cable-1087
In Stock 6
Price: $29.99
OSE .130" flex cable with 4mm Propeller Shaft for 4mm props.
Includes:
(1) .130 Flex Cable glued to 4mm) Shaft. 18" (450mm) from end to end.
(1) Propeller Shaft, 4mm diameter, 76mm Long, pn# etti-a039
(1) Drive Dog pn# ose-80005
(1) Prop Nut
(1) Cable system approx 18" long
(1) .130 Teflon Tubing: pn# oct-130T-24
Requires:
1.5mm Driver
7/32 OD K&S brass tubing pn# 8130 for stuffing tube when used with the Teflon liner.
3/16 OD K&S brass tubing pn# 8129 for stuffing tube when used with NO Teflon liner.
- Cut the cable to the needed length.
- Make a flat spot on the shaft where you would like the drive dog set and tighten the 1.5mm grub screw.
OSE .130 reversed (right) cable with 4mm prop shaft
Product ID ose-cable-1087-R
Price$29.99
