OSE .187 (3/16") cable with 3/16" prop shaft 3.25 long
Product ID ose-cable-1190
List Price: $32.99
Price: $27.99
OSE assembled 3/16" (.187) Flex cable with 3/16" (.187" 4.75mm) diameter propeller shaft.
For use with 3/16" propellers and struts with 3/16" (.187) bushings or bearings.
We offer these in
24" or 30" total assembled length.
NOTE: Flex cable lengths are from the tip of the shaft to the end of the cable. For example, 24" cable is approx 21" of cable and 3.25" of prop shaft. Lengths are approximate and can be plus or minus one-half inch. These assemblies require the customer to cut the cable to its required length.
Includes:
.187" (4.74mm) diameter flex cable.
.187" (4.74mm) propeller shaft 3.25" (83mm) Long
Requires:
3/16" Drive Dog
10-32 Nut
Teflon Tubing .187 Size
OSE Strut for Traxxas Spartan for convert to 3/16" Prop Shaft
1 of 3
Product ID ose-83227
Price$24.95
OSE .187 (3/16") reversed (right) cable with 3/16" prop shaft 3.25" long
Product ID ose-cable-1190-rev
Price$27.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$4.49
Drive Dog for 3/16" (4.75mm) Prop Shafts : 8mm OD
1 of 2
Product ID tfl-518b22
Price$2.99
Octura Small Drive Dog for 3/16" Prop Shaft
Product ID oct-oc6dmm
Price$3.49
Octura Large Drive Dog for 3/16" Prop Shafts
Price$3.49
Tapered Drive Dog for 3/16" Prop Shafts : 10mm to 8mm OD
1 of 2
Product ID ose-80248
Price$2.99
Octura Brass Bullet Nut for 3/16" shaft (10-32 thread)
Product ID oct-oc6pnmm
Price$3.79
Zuber Prop Nuts for 3/16" Shaft with 10-32 threads (3 Pack)
1 of 2
Product ID ose-zn-8135
Price$2.99
Du-bro Cut Off Wheel & Mandrel, 1-1/4"
Product ID hh-353
Price$5.99
Octura 3/16" (4.75mm) Shaft Thrust Washers(10 pack)
Product ID oct-oc6twmm
Price$3.99
