OSE 1/4" cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
Product ID ose-cable-1290
In Stock 0
Price: $34.99
OSE assembled .250 (1/4") cable to 1/4" propeller shaft w/stepped down shaft end for 3/16" (.187) Propellers.  This item can be used with the 1/4 struts but has the ability to use the smaller 3/16" props for better tuning.
This shaft can be used with 3/16" drive dog-style props.
Specs:
Flex Cable diameter: 1/4 (.250", 6.35mm)
Assembled length: 32" (800mm)
Specs of the prop shaft, see picture 2
Shaft total length: 4.25" (108mm)
Propeller shaft diameter: 3/16" (4.75mm)
Propeller shaft length: 1.75" (44.4mm)
Requires:
Drive Dog 3/16" or for large hub props you can put on a 1/4" drive dog on the 1/4" section.
Prop nut with 10-32 thread.
Teflon tubing 1/4" size.
These assemblies require the customer to cut the cable to its required length.
Note:
The OSE listed length is the total assembled length. Measured from the end of the cable to the tip of the propeller shaft. Flex cable lengths are approximate. They can be plus or minus one-half inch. These assemblies require the customer to cut the cable to its required length.
OSE Propeller Adapter
1 of 5
Product ID ose-83400
Price$1.99
2 to 1 Transfer Case
1 of 10
Product ID tfl-525b85
Price$99.99
OSE Raider M40 Hull (39.75" 1010mm)
1 of 7
Product ID ose-Raider-M40
Price$299.99
Speedmaster Large 1/4" (.250) Strut
Product ID ros-spds-008
Price$34.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
OSE 1/4" reversed (right) cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290-rev
Price$34.99
Strut for 45 Inch (1150mm) catamaran 140mm long
1 of 3
Product ID tfl-503b85
Price$59.95
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$4.49
1/4 Adjustable Stinger Strut
1 of 6
Product ID tfl-503b82
Price$46.99
Octura Small Drive Dog for 3/16" Prop Shaft
Product ID oct-oc6dmm
Price$3.49
Octura Large Drive Dog for 3/16" Prop Shafts
Price$3.49
Drive Dog for 3/16 (4.75mm) Prop Shafts : 10mm OD
1 of 2
Product ID ose-80246
Price$2.99
Tapered Drive Dog for 3/16" Prop Shafts : 10mm to 8mm OD
1 of 2
Product ID ose-80248
Price$2.99
Octura Brass Bullet Nut for 3/16" shaft (10-32 thread)
Product ID oct-oc6pnmm
Price$3.79
Zuber Prop Nuts for 3/16" Shaft with 10-32 threads (3 Pack)
1 of 2
Product ID ose-zn-8135
Price$2.99
Du-bro Cut Off Wheel & Mandrel, 1-1/4"
Product ID hh-353
Price$5.99
Octura 3/16" (4.75mm) Shaft Thrust Washers(10 pack)
Product ID oct-oc6twmm
Price$3.99
