OSE 1/4" reversed (right) cable with 1/4" prop shaft x 30" (760mm) Long
Product ID ose-cable-1295-rev
In Stock 0
Price: $32.99
OSE assembled .250 (1/4") reversed cable with 1/4 Propeller shafts. These can be used with 1/4"(.250") struts.
NOTE: This is REVERSED CABLE. The cable in this package is designed for propellers that spin clockwise, such as the Octura "R" series right props or the Graupner left props.
Specs:
Flex Cable diameter: 1/4 (.250", 6.35mm)
Propeller Shaft length: 4.40" (114mm)
Propeller shaft diameter: 1/4" (.250", 6.35mm)
Assembled length: 30" (760mm)
Requires:
1/4" Drive Dog
1/4 threaded nut.
Teflon tubing 1/4" size
Note:
The OSE listed length is the total assembled length. Measured from the end of the cable to the tip of the propeller shaft. Flex cable lengths are approximate. They can be plus or minus one-half inch. These assemblies require the customer to cut the cable to its required length.
2 to 1 Transfer Case
1 of 10
Product ID tfl-525b85
Price$99.99
Speedmaster Large 1/4" (.250) Strut
Product ID ros-spds-008
Price$34.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$4.49
Octura Drive Dog with two set screws for 1/4 Prop Shafts, 7/16" OD
1 of 2
Product ID oct-oc8dmd
Price$2.99
Octura Drive Dog with two set screws for 1/4 Prop Shafts, 1/2" OD
Product ID oct-oc8d
Price$3.29
Octura Brass Bullet Nut for 1/4" shaft
Product ID oct-oc8pnm
Price$3.49
Zuber Prop Nuts 1/4" Shaft with 1/4-28 threads (3 Pack)
1 of 2
Product ID ose-zn-1428
Price$2.99
Prop Nuts 1/4" with nylon locking for 1/4-28 threads
Product ID tfl-530b24
Price$0.99
Du-bro Cut Off Wheel & Mandrel, 1-1/4"
Product ID hh-353
Price$5.99
Octura 1/4" (6.35mm) Shaft Thrust Washers(10 pack)
Product ID oct-oc8twm
Price$3.99
