OSE .130 cable with 3/16" prop shaft
Product ID ose-cable-130L
In Stock 5
Price: $32.99
OSE assembled .130 flex cable with 3/16" prop shaft, drive dog, basic nut, and teflon liner.
Our assembled systems use the latest in assembly technology. We don't heat the cable in our process. This helps solve the breaking problems at the solder joint that other companies have.
Includes:
(1) .130 Flex Cable glued to 3/16" (4.75mm) Shaft. 18" (450mm) from end to end.
(1) Propeller Shaft, 3/16" (4.75mm) diameter, 2.25" (57mm) Long, pn# oct-oc6130ps
(1) Drive Dog pn# tfl-518b22
(1) Prop Nut: pn# ose-8135
(1) Cable system approx 18" long
(1) .130 Teflon Tubing: pn# oct-130T-24
Requires:
1.5mm Driver
7/32 OD K&S brass tubing pn# 8130 for stuffing tube when used with the Teflon liner.
3/16 OD K&S brass tubing pn# 8129 for stuffing tube when used with NO Teflon liner.
- Cut the cable to the needed length.
- Make a flat spot on the shaft where you would like the drive dog set and tighten the 1.5mm grub screw.
OSE .130 reversed (right) cable with 3/16" prop shaft
Product ID ose-cable-130R
Price$32.99
