OSE .150 cable with 3/16" prop shaft 2.25" long
Product ID ose-cable-150L
In Stock 1
Price: $32.99
OSE assembled .150 flex cable.
Our assembled systems use the latest in assembly technology. We don't heat the cable in our process. This helps solve the breaking problems at the solder joint that other companies have.
Includes:
(1) .150 Flex Cable glued to 3/16" (4.75mm) Shaft. 18" (450mm) from end to end.
(1) Propeller Shaft, 3/16" (4.75mm) diameter, 2.25" (57mm) Long, pn# oct-oc6150ps
(1) Drive Dog pn# tfl-518b22
(1) Prop Nut: pn# ose-8135
(1) Cable system approx 18" long
(1) .150 Teflon Tubing: pn# oct-150T-24
Requires:
2mm Driver
7/32 OD K&S brass tubing pn# 8130 for stuffing tube when used with the NO Teflon liner.
1/4 OD K&S brass tubing pn# 8131 for stuffing tube when used with the Teflon liner.
- Cut the cable to the needed length.
- Make a flat spot on the shaft where you would like the drive dog set and tighten the 2mm grub screw.
1 Product Reviews - Average rating 5 / 5 (Show All)
Errol Escoffery - 14th July 2026
OSE .150 reversed (right) cable with 3/16" prop shaft 2.25" long
Product ID ose-cable-150R
Price$32.99
Speedmaster Stinger Strut
1 of 7
Product ID ros-stinger-str
Price$59.99
Octura .150 cable system for 3/16" props
Product ID oct-oc150L-24c
Price$14.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
Recently Viewed
Pick up where you left off.
