OSE .150 reversed (right) cable with 3/16" prop shaft 2.25" long
Product ID ose-cable-150R
In Stock 1
Price: $32.99
OSE assembled Octura .150 Right lay flex cable with 3/16" prop shaft, drive dog, basic nut, and teflon liner. Flex Cable is approx 18" Long.
The cable in this package is made for propellers that spin clockwise. For example, Octura props that end in the letter "R" or Graupner props that end in the letter "L".
Our assembled systems use the latest in assembly technology. We don't heat the cable in our process. This helps solve the breaking problems at the solder joint that other companies have.
Includes:
(1) .150 Flex Cable glued to 3/16" (4.75mm) Shaft. 18" (450mm) from end to end.
(1) Propeller Shaft, 3/16" (4.75mm) diameter, 2.25" (57mm) Long, pn# oct-oc6150ps
(1) Drive Dog pn# tfl-518b22
(1) Prop Nut: pn# ose-8135
(1) Cable system approx 18" long
(1) .150 Teflon Tubing: pn# oct-150T-24
=Requires:
2mm Driver
7/32 OD K&S brass tubing pn# 8130 for stuffing tube when used with the NO Teflon liner.
1/4 OD K&S brass tubing pn# 8131 for stuffing tube when used with the Teflon liner.
- Cut the cable to the needed length.
- Make a flat spot on the shaft where you would like the drive dog set and tighten the 2mm grub screw.
OSE .150 cable with 3/16" prop shaft 2.25" long
Product ID ose-cable-150L
Price$32.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
