OSE .150 reversed (right) cable with 3/16" : 3.00" long prop shaft
Product ID ose-cable-150R-xL
In Stock 0
Price: $32.99
OSE assembled .150 Right lay flex cable with extra-long 3.00" (76mm) long, 3/16" prop shaft, drive dog, basic nut, and teflon liner. Flex Cable is approx 22" Long.
The cable in this package is made for propellers that spin clockwise. For example, Octura props that end in the letter "R" or Graupner props that end in the letter "L".
Our assembled systems use the latest in assembly technology. We don't heat the cable in our process. This helps solve the breaking problems at the solder joint that other companies have.
Includes:
(1) .150 Right lay Flex Cable
(1) Propeller shaft, 3/16" (4.75mm) diameter, 3.00" (76mm) Long, pn# oct-oc6150psL
(1) Drive Dog pn# oc6dmm
(1) Prop Nut: pn# ose-8135
(1) Cable system approx 20" long
(1) .150 Teflon Tubing: pn# oct-150T-24
Requires:
7/32 OD K&S brass tubing pn# 8130 for stuffing tube when used with the NO Teflon liner.
1/4 OD K&S brass tubing pn# 8131 for stuffing tube when used with the Teflon liner.
Cable cut to your desired length.
OSE .150 cable with 3/16" : 3.00" long prop shaft
Product ID ose-cable-150L-xL
Price$32.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
