OSE .187 (3/16") cable : drive dog : bullet nut : 3/16" prop shaft : 3.25" long
Product ID ose-cable-187-XL
In Stock 0
Price: $39.99
OSE assembled 3/16" (.187") Cable with 3/16" prop shaft, 3.25 (83mm) long..
The cable assembly is approximately 24" (600mm) from end to end. The flex cable is soldered directly to the propeller shaft. Drive dog slot is machined for a perfectly flat spot to attach the drive dog to.
Includes:
(1) 3/16" (.187") (4.75mm) .187 Flex cable assembled to 3/16" (.187") (4.75) diameter propeller shaft 3.25" (83mm) long.
(1) Drive Dog pn# tfl-518b22
(1) Brass Bullet nut pn# oc6pnmm
(1) Thin Nut pn# oct-n1032
Requires:
1/4 OD K&S part# 8131 brass tubing for stuffing tube when used with the NO Teflon liner.
9/32 OD K&S part# 8132 brass tubing for stuffing tube when used with the Teflon liner pn# ose-oc187T-24.
Customers to cut to their desired length.
 x   (x)
Speedmaster Stinger Strut
1 of 7
Product ID ros-stinger-str
Price$39.95
TFL Aluminum CNC Adjustable Stinger drive for 3/16 (4.76mm) shaft
1 of 2
Product ID tfl-503B70
Price$29.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$4.49
Complete Rudder Assembly w/ Prop Wash Water Pickup
1 of 6
Product ID tfl-502b32
Price$49.99
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler
Product ID ose-81518
Price$9.95
