OSE .130 reversed (right) cable with 3/16" to 1/8" stepdown prop shaft
Product ID ose-cable-64pkg-R
In Stock 3
Price: $29.99
OSE assembled .130 right lay flex cable with prop shaft that is a stepdown 3/16" to 1/8" for 1/8" propellers.
The propeller shaft works with 3/16" struts. This option is good for a high powered small boats that need the strength of larger cable and prop shafts.
The cable in this package is made for propellers that spin clockwise. For example, Octura props that end in the letter "R" or Graupner props that end in the letter "L".
Our assembled systems use the latest in assembly technology. We don't heat the cable in our process. This helps solve the breaking problems at the solder joint that other companies have.
Includes:
.130 reversed cable, approx 16" total assembled length.
.130 teflon liner
1/8" brass drive dog
1/8" brass bullet nut
Requires:
7/32 OD K&S brass tubing for stuffing tube when used with the Teflon liner.
Cable cut to your desired length.
