OSE Heavy Duty upgraded flex cable for TFL Lucky, Smash Shark and Patron Saint with Standard strut
Product ID ose-cable-HD-SmashShark
In Stock 1
Price: $39.99
OSE Heavy Duty Flex Cable for the TFL Smash Shark
OSE .187" Cable with 3/16" prop shaft. This cable measures .187" (4.75) in diameter. This cable is cut and ready to install into a stock TFL Smash Shark with no other modifications. Just remove the old cable, insert your new OSE HD cable, tighten it, and you're ready to go! Comes as pictured with a bullet nut, thin nut, and tapered drive dog.
**Propeller is not included**
Benefits over stock cable:
Thicker gauge flex cable windings.
5mm longer flex cable for added grip within the stock coupler.
A soldered end for both added grip within the coupler and help with the unwinding of the cable end.
No soldering or cutting is required!
This can also be used in any other boat requiring a .187" cable that measures approx. 240mm(+/-2) from tip to tip.
How-To Guides Using This Part
The basics on flex cables
All how-to articles
TFL Patron Saint Lucky ARTR : Stinger Strut : 3674 2075kv v2 motor : Seaking 180
1 of 5
Product ID tfl-1126L-F
Price$549.99
